Help with MOSFET H-bridge
Haris Shafiq
Newbie level 2
Newbie level 2
I've designed an H-bridge circuit
(https://obrazki.elektroda.pl/4652666800_1375483001.jpg),
kindly help me out if it has any errors?
Q: someone told me to put boost capacitor between gate and source of high side mosfet when u r running high voltage motor, e.g; 48 volts.
Q: some values are not known by me, so if anyone of u can guide it will be much appreciable.
Q: also, if this circuit has any errors, kindly tell me because I've made this type of circuit for the first time and i don't want to burn any hardware before confirming that it's circuit is OK.
thanks.
http://obrazki.elektroda.pl/9824587900_1375483000.jpg
its another image of circuit, sorry for the bad image quality, i havnt got any good camera :lol:
Don't put any capacitor between the gate and source of the MOSFET.
You seem to have shorted VB and VS. Remove the short.
Put gate resistors between the IR2110 gate-drive-outputs and the MOSFET gates.
Put 1k resistors between gate and source of each MOSFET.
Remove the resistors and capacitors between the opto-coupler emitter and the gates.
For further information/ideas regarding the IR2110, refer to this: https://tahmidmc.blogspot.com/2013/01/using-high-low-side-driver-ir2110-with.html
Hope this helps.
Tahmid.
Hope this helps.
Tahmid.
Thanks Tahmid for the reply, but i used resistor and capacitor combination at optocoupler emitter as low pass filter, so that i can prevent shoot thru in the circuit, and shimitt trigger to make it discrete again, is it wrong?
Vb and Vs are connected the same way as they are connected in your blog, am i missing something?
