Help with Low-Noise-Amplifiers
raghav
Junior Member level 3
I request u all 2 help me with links and uploads related to LNAs.
Pls hurry up its urgent.
Manjunatha_hv
Advanced Member level 3
INDIA
Following are the good documents on LNA design using RF CAD tool (Microwave Office)
1. 17GHz and 24GHz LNA Designs based on Extended S-parameter with Microstrip-on-Die
in 0.18µm Logic CMOS Technology paper (PDF) by Intel Research & Development
http://www.appwave.com/src/news/articles/AR0307.pdf
2.Broadband_RF_LNA.pdf
3. Designing a Low-Noise Amplifier with VoltaireLS (LNA_Appnote.pdf) by Maas
and
4. **broken link removed**
I hope this helps in LNA design & analysis
good luck
STOIKOV
Full Member level 4
this is one of the most cited papers about LNA
rriizzwwaann
Newbie level 1
vellore
sir,
i want to drsign cmos LNA using awr tool .In my circuit i hav each and every value.
i draw that same ckt in tool but i am not getting same results.
For s11,s22,s12 parameters i want nagative values but i am getting positive values.
for gain(s21),i want positiv value but i am gettng negative value.
plz send somae awr manual + cmos LNA design and i am sending my ieee paper also
plz help me..
  • main paper.pdf
DDavid
Full Member level 5
sorry but how u know that transistor model is correct?
Manjunatha_hv
INDIA
Hello Rizwan,
OKay no problem we can help to resolve these issues...
I went through the article & found the following, in order to construct MWO schematic...
What Type of CMOS device Model Parameters you used? (say BSIM model with exact parameters)
Or Do you use the S-parameter file of the CMOS Device model?
Or Do you use any specific Process Design Kit (PDK) CMOS model such as TOWERJAZZ? or TSMC?
Send / uplod your AWR MWO project file *.emp so that I will try to help you better...
---manju---
