nitsakh
Member level 1
I want to write a simple linked list program with ASM .
Here's the code which I have tried to write(presently only for single digit numbers) ! However,it works only for 4 numbers and that too has sometimes some errors. I am new to assembly language.
So please help me as to what I am supposed to do,as I am in fix !
.model small
.data
m1 db 10,13,'Enter Data :: $'
m2 db 10,13,'Continue ?? $'
head dw 0 ;variable for head node address
.code
mov ax,@data
mov ds,ax
mov bx,1 ;size in paragraphs to allocate
mov ah,48h ;function to allocate memory dynamically
int 21h
mov head,ax ;copy address of new block to head
mov dx,offset m1
mov ah,09h ;Display string m1
int 21h
mov ah,01h ;Accept character from keyboard
int 21h
xor ah,ah
mov bx,head
mov [bx],ax ;copy accepted value to memory
mov di,head ;copy address of head to di
mov dx,offset m2
mov ah,09h ;display string m2
int 21h
int 21h
cmp al,'y' ;Continue in case of Y
je loop1 ;else skip
cmp al,'Y'
je loop1
jmp below
loop1:
mov bx,1
mov ah,48h ;Allocate 1 paragraph dynamically
int 21h
xor si,si
mov [di+2],ax ;Store address of new paragraph in di+2
xor di,di ;i.e.next pointer of previous node
mov si,ax ;copy new address to si
mov dx,offset m1
int 21h
mov ah,01h
int 21h
xor ah,ah
mov word ptr [si],ax ;copy accepted value to memory
mov di,si ;copy new address to di
mov dx,offset m2
mov ah,09h
int 21h
mov ah,01h
int 21h
cmp al,'y'
je loop1
cmp al,'Y'
je loop1
below:
mov word ptr [di+2],0 ;set next field of last node to 0
disp:
mov ah,02h ;Display character
mov dx,10
int 21h
mov dx,13
int 21h
mov bx,head ;copy address of 1st node to bx
mov ah,02h
mov dx,[bx] ;Display value at head node
int 21h
lp:
mov ah,02h
add bx,2 ;go to next field of current node
mov dx,word ptr [bx] ;retrieve value at this address
int 21h
cmp word ptr [bx+2],0 ;compare this value with zero
jnz lp ;if it is zero,then stop displaying
exit:
mov ah,4ch ;Exit program
int 21h
end
