zipdogso
Newbie level 3
- Joined
- Jul 19, 2009
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- South London, UK
- Activity points
- 1,351
led circuits
Until last year when I dabbled briefly I hadn't picked up a soldering iron for over 2 decades and forgotten most of what I learned....but my recent project requires amongst other things for me to go back and do electronics again.
My problem is I need to have an LED display for the state of a fan thus:-
1./ the LED is off either the fan or something worse has gone wrong.
2./ the fan is attached to power but not rotating. (RED LED.)
3./ the is powered and running. (GREEN LED.)
To break myself back in gently I have been trying a few things on the bread board.
The schematic attached ( not a good one i admit.) is where I have got to so far and works.
On the left of the relay (as you look at it.) is a simple constant current LED driver circuit. On the right is the fan it is 12v 1.5amp 12cm. The relay is DPDT. I am running both the LED circuit and the fan from the same supply and I wanted to be able to adjust the fan input hence the constant current LED circuit.
As shown in the schematic everything works fine just for testing I also ran the relay coil off the same supply as well with a switch to turn it on and off.
BUT.....
1./ It doesn't satisfy my first fan state i.e. if the fan breaks down the LED will continue to show red or green. At the moment I can only think I will have to run the fan on the relay coil circuit with the coil going to the base of a transister and the collector driving the fan (due to the 1.5amp current draw of the fan.)and add an extra relay for the red/green states but I havent come up with anything beyond this yet.
2./ I really wanted to use 2 lead bicolor LEDs I have 3 fans to monitor, temp outputs and allsorts so I would prefer one LED display per fan.
Any ideas ?
BUT.....
Any ideas ?
