I am attempting to build a 35amp PWM motor controller for a brushed DC motor application (electric bike).
I successfully sizzled a n-fet for first test. I was able to spin up the motor, then it burned out and stuck on. After that, I hooked up the current sensor, and successfully sizzled the IR2110-2 driver, it was cooking on top.
I picked up 1-4 amps during the last test, spun it up lightly a few times, then throttled it back down to 0%. After a couple seconds, I noticed a funky smell and something boiling on top of the IR2110.
Here is the circuit...any ideas why I smoked it?
The OpAmp is really the ACS756 current sensor:
Arduino Code
_____________________________________________
Code C - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
| // Alpha Motor Control program written by Steelmesh
// IR2110 Driver
// 75321 N-mosfet
// ACS756 hall effect current sensor, two 0.1uf caps for VIN/VOUT
// Hall Sensor pins: (1)VCC- 5v Arduino, (2)GND- Ground Arduino, (3)VIOUT- Analog Input Arduino, (4) from power source, (5) to load
int LIN = 3; //Low PWM to IR2110 LIN
int hallIn = 2; //signal from Hall Sensor
int ampLimit = 10; //manual input
int sensorCal = 511; //manual input
int sensorSpec = 40; //40 mV per Amp
void setup()
Serial.begin(9600);
void loop()
int throttleIn = analogRead(4); //Read throttle, declare integers
int pulse = constrain(throttleIn, 200, 800);
pulse = map(pulse, 200, 800, 0, 254);
int ampRead = analogRead(hallIn); //Read hall sensor output
ampRead = constrain(ampRead, sensorCal, 1023); //constrain to manual sensor calibration
int actualAmp = ampRead - sensorCal; //Declare new int for conversion
actualAmp = (actualAmp * 4.9) / sensorSpec; //4.9 * Analog signal =~ mV, divide by example: "ACS756 spec: 40mV/1A"
int hallMv = analogRead(hallIn) * 4.9; //debugging to view mV
Serial.print("Pulse: ");
Serial.print(pulse);
Serial.print(" ");
Serial.print("Amps: ");
Serial.print(actualAmp);
Serial.print(" ");
Serial.print("Hall mv: ");
Serial.print(hallMv);
Serial.println("");
if (actualAmp > ampLimit) //current limiter function
pulse = 0; //turn off via pulse
analogWrite(LIN, pulse);
Serial.println("OVERLIMIT!!");
delay(100);
else
analogWrite(LIN, pulse); //Within 'if' statement to ensure if actualAmp > ampLimit, it won't command analogWrite(throttle function)
delay(100); //Serial.print sake
__________________________________________________ _-
