rudie
Junior Member level 3
Hello guys,
I am using the MAX4194 to measure the voltage across a resistor (R2). I chose the MAX4194 because it has a voltage error of 450 uV at a gain of 1. It also has a low gain error. To test if it works i build up a simple circuit (see atachment). As stated in the datasheet i connected a Rload of 25K (R5) to Vcc/2. The Vcc/2 is realized by the voltage divider of R3 and R4. I did not connect a resistor to select the gain because if you leave the pins open the gain is one. The Vcc is 5V. If i measure the output pin it has an inaccuracy of 4mV!!!! and not 450 uV. How is this possible, what did i do wrong?
Please help
greets Rudie
Please help
greets Rudie
