infinite_gbps
Member level 3
Thanks for the help.
The simplest network to match 60.95, -45.75 at 300MHz is to shunt the 60.95, -45.75 with a 1.1pF capacitor and then place a 25nH inductor in series between the 50 Ohm port and the load. This is another L match.
The other way to do it is to cancel out the -45.75 with a series 45.75 ohm (24.3nH) from the load and then you just have to match 50 ohm to 60.95 Ohm. You can do this with a regular L match.
So you end up with a series 12.1nH leaving the 50 ohm port, then a shunt 4.0pF followed by the series 24.3nH. This second network will have slightly more bandwidth.
