I used HDL Designer 2002 and now I want to switch to HDL Designer 2003.
But, I have a problem that HDL Designer 2003 can't read very well the project maded in HDL Designer 2002. The problem is that version 2002 stored the src, hdl, etc files in diferent locations than HDL Designer 2003.
Anyone here have this problem or know how could I fix this?
OK! My Dear friend the solution is so simple, just go to File->New->Library and then, a dialog will appear asking you the path to your project folders, for the HDL directory enter the path of your previous HDL directory, for HDS directory, enter the path of your src. ( uncheck the Auto botton ) Answer all of the remaining questions, which are easy. That was it all. OK?
