Al J
Newbie level 5
Having trouble with a current sensing circuit used to detect if a break light is out (automotive.) The attached is what I managed to trace from the card.
The highlighted chip is a 5 pin op-amp that I cant cross reference. I am not certain of the polarity of either of the transistors, nor of which pin is base and which is collector on the highlighted transistor. Help would be appreciated!
1) probable polarity of the two transistors
2) which pin is B and which is C on highlighted transistor
3) probable pin out of the op-amp.
4) how the heck this thing works.
Thanks for any help you can give.
