Androxys
Newbie level 2
Hello everyone, first time poster, and in dire need for assistance.
So I have an instrumentation op-amp, the INA111 Instrumentation Amplifier - Dual Supply - INA111 - TI.com
I am supplying it with +-9Vdc, and am using an LMC7660 converter **broken link removed** to switch the 9V to -9V. However I am having two issues with it.
I am using two 10uF electrolytic capacitors like the datasheet says to, and every pin is connected properly, according to the sheet. However at the output I am having only -6.5V, rather than -9V as was supposed to. And even worse than that, when I connect the LMC7660's output to the V- pin of the INA111, the voltage drops to -0.6V, which isn't near enough for my application.
Some reading of the datasheet of the LMC7660 leads me to believe that this probably has something to do with the load current, but that is as far as I can go with solving the problem myself. I investigated a little but no luck yet.
Anyone has an idea of how to solve this?
Thank you very much in advance.
