gsuarez
Junior Member level 1
The circuit has the following parameters:
Check the circuit www.ece.uprm.edu/~s988025/pub/bandgap.png
Is=10^-15 A
dVbe/dT = -2.2mv/C
Temperature coefficient of 1500ppm/C
Voltage Coefficient of 100ppm/C
I'm not sure what is the relationship between the output voltage (Vref) and the temperature coefficient and the voltage coefficient. I know that Vref = Vout and can be found by Iref*R2+Veb4.
Since Veb4 is Vt*ln(Iref/Is) = (kT/q)*ln(Iref/Is) I can determine this amount for a particular temperature, but where does the temperature and voltage coefficient fit into all this?
Is=10^-15 A
dVbe/dT = -2.2mv/C
