JHEnt
- Joined
- May 23, 2014
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 80
I have been having trouble getting a Maxim MAX2769B chip to work on a protoboard. I'm hoping someone here has worked with one of these before. Basically I have tried mounting several to proto-advantage boards. The latest one I took extra care to mount all mount all of the decoupling, AC coupling, DC blocking capacitors and the PLL CRC filter onto the board with SMD components. It seemed although I had no I/Q outputs that the chip was otherwise functioning. It was outputting 3.2 volt on the ANT-BIAS pin and for a while I had a 2.5 volt output on the PLL lock indicator pin. I could also pick up millivolt levels on the RF in out and external XTAL leads. I have laid out the board along the "typical application circuit" in Maxim's spec sheet. Is there something non-obvious I'm doing wrong? I have read very few cases where this chip was used in projects online except when mounted on the evaluation kit direct from Maxim. I have read several blogs ect where a problem sounding much like mine is reported.
I am trying to use LNA1 input. I'm powering it with 3.3volt. I am using an Abracon 16.38676MHz TXCO with a 10nF coupling capacitor to the external reference pin. I'm pulling up the IDLE, SHTDWN pins and grounding the PGM so as to use a preconfigured state by pulling the SDATA high and the SCLK and CS pins low.
I have tried mounting these myself. I certainly wouldn't exclude the posibility of solder shorted contacts under the chip but then why should it seem to be functioning and then just stop.
Is there anyone who has made one of these chips work?
