I have a gateway lp2407 that will not turn on . It has a switchless control I.E. capacitive or inductive. I have checked the esr values of all caps and all checked ok I removed the caps to insure that were no parrell paths . I have 135 vdc at the filter caps on the power board . No dry connections are apparent . any suggestions for further trobel shooting would be appreciated .
Thanks in advance
Try to test short circuit at output side of power supply and also check Stby circuit
and check this web site for more information related your Question Gateway 24" LCD Model LP2407 - Badcaps Forums
