help: what does this c code signify
alvarorahul
what is the significance of the colon in the following code
struct abc
int bit1:1;
int bit3:4;
int bit4:4;
}xyz(1,2,2);
main()
//code
struct abc
int bit1:1;
int bit3:4;
int bit4:4;
}xyz(1,2,2);
These are packed bit fields. The number after the colon is the length. The compiler will pack these into an integer if possible. Usually this is only needed if memory is at a premium. Generally it is best to use unsigned int instead of int so no bits are added for the sign.
So in the xyz variable,
xyz.bit1 = 1 and is 1 bit long
xyz.bit3 = 2 and is 4 bits long
xyz.bit4 = 2 and is 4 bits long
All the above values will be automatically converted to int.
I don't know what happened to bit2. But it could have been set to a 7 bit variable without increasing the memory use.
Use bit fields with caution as they are not very portable between platforms (int16 vs 1in32).
Hope this helps
i did not understand this part........how is it this can be done?
even so .........int is 2 bytes right? so even if we do 15 bit variable bit2 then also it shd happen widout extra memory being used?
am a little confused.........pls explain :?:
I may help you more if you can tell me in what application you need this.
If you are just asking this to increase you C Aptitude, then you will be better off asking at C Newsgroup than EDABoard.
But if this is formware related, better give a more complete snippet of code and I iwll try to help you out.
The definition of 'int' is platform dependent, i.e. it depends on what compiler you're using since compilers are free to set the size of int.
My explanation was assuming that an integer was 16 bits and by adding a bit2 of 7 bits long, the total bits used would be 16
bit1 length = 1
bit2 length = 7
bit3 length = 4
bit4 length = 4
total =16 bits = one integer
If you're writing code for the PC, more than likely your compiler has 32 bit integers. Some microprocessor compilers have 16 bit integers. I haven't ever used a C compiler with 8 bit 'int' that supports bit fields.
Does this clear it up?
