Help w/ a 4 bit universal shift register.
NerdyRocker54
I want to implement a sequential circuit using verilog that functions as a 4-bit universal shift register. The shift register will have two inputs that specifies which function the register will perform: 0 0- No change, 0 1-Shift Right, 1 0- Rotate Left, 1 1- Parallel Load
If the shift register is performing a right or left shift it is to get its input from the serial input. Everything is happening at the posedge of the clock.
I need help with the the structural implementation that uses 4 4-to-1 muxs and 4 1bit D-ff modules.
So far i have a 4:1 mux, a D-FF, and a "debounce" module, as well as a schematic.
4:1 Mux
module 4to1_mux(data,out,sel);
input [3:0]data;
input [1:0] sel;
output out;
reg out;
always @(data,sel)
begin
case ({data,sel})
2'b00: out = out;
2'b01: out = data[1];
2'b10: out = data[2];
2'b11: out = data[3];
default: out = 2'bXXXX;
endcase
end
endmodule
module dFF(D,Q,clk,rst);
input D,clk,rst;
output Q;
reg Q;
always @ (posedge clk, posedge rst)
begin
if (rst==1'b1)
Q <= D;
else
Q <= Q;
end
endmodule
