help!! VHDL problem! About frequency counter
hlmwps
Newbie level 1
freqmeter by fpga
entity FreqMeter is
port (reset : in std_logic ;
CE : in std_logic ;
bclk : in std_logic;
gclk : in std_logic;
start : in std_logic;
num : in integer range 10 to 1000;
over : out std_logic ;
databus : out std_logic_vector (47 downto 0)
end FreqMeter;
architecture Behavioral of FreqMeter is
signal bz_count : integer ;
signal gc_count : integer range 0 to 1000 ;
signal bz_ena,ena : std_logic;
signal clr : std_logic;
signal tmp_start,tmp_over : std_logic;
signal resetn ,resetd : std_logic;
begin
databus <= conv_std_logic_vector(bz_count,48) ;
process (CE,start) begin
if CE='0' and start='0' then
resetn <= '0' ;
elsif CE='0' and rising_edge(start) then
resetn <= '1' ;
end if;
end process;
process (bclk)
begin
if rising_edge (bclk) then
resetd <= resetn ;
end if;
end process;
clr <= resetn and (not resetd) ;
over <= tmp_over ;
process (reset,clr,start)
begin
if reset='0' or clr = '1' then
tmp_start <= '0' ;
elsif falling_edge(start) then
tmp_start <= '1' ;
end if;
end process;
process (reset,clr,tmp_over,ena,tmp_start)
begin
if reset='0' or clr = '1' or (tmp_over='1' and ena='0') then
bz_ena <= '0' ;
elsif rising_edge(tmp_start) then
bz_ena <= '1' ;
end if;
end process;
bzcounter: process (reset,bclk,clr,bz_ena,ena)
begin
bz_count <= 0 ;
elsif rising_edge (bclk) then
if bz_ena = '1' and ena = '1'then
bz_count <= bz_count+ 1;
end if;
end if;
end process;
gccounter: process (reset,gclk,clr,bz_ena)
begin
if reset='0' or clr = '1'then
gc_count <= 0 ;
tmp_over <= '0' ;
ena <= '0' ;
elsif falling_edge (gclk) then
if bz_ena = '1' then
gc_count <= gc_count+ 1;
if gc_count=num then
ena <= '0';
gc_count <= num-1 ;
tmp_over <= '1' ;
else
ena <= '1';
tmp_over <= '0' ;
end if ;
end if;
end if;
end process;
end Behavioral;
Added after 5 minutes:
Above is a VHDL example about frequency counter!
I simulate it with Modelsim 6.0 ! It can work very well and the function is good!
But when I download it into a Xinlix CPLD XC95144XL,its function doesn't do well!
Please help me to find where is the error!
CPLD's and FPGAs are ment for synchronous logic circuits.
Your logic contains so many asynchonous blocks. And this is the problem!
First of all you make the whole logic synchronous!
Check out the internals of the CPLD and see what is allowed and what is not!
