louarnold
Member level 2
How do I determine if the USB port is actually getting data to/from the system's COM port?
Some info:
- I purchased a Generic USB to RS232 adapter based on a PL2303 chip.
- I have installed drivers on both Vista Home Premium and Windows XP SP3 machines.
- The driver that came with the adapter seems to have installed properly.
- I have RealTerm installed.
- I jumpered Tx to Rx plus other pins on the male DB9 connector.
- I sought help from Prolific (re PL2303), but found nothing helpful there.
- It is the USB port that adapter is plugged into. The RS232 DB9 will go to serial device once its tested.
But I don't know how to look for data passing through the adapter. What I type on the keyboard does not show up on the RealTerm screen.
I am stumped, and about to cut the vinyl covers of the adapter to see if I can find the problem that way.
Some info:
