hi guys,
I am Newbie to Micro controller, currently doing Final year project, need help on RF module transmitting/Recieving from PIC to PIC.
Best if there is an schematics diagram and asm code.
thanks
It is very simple to interface TX RX modules with PIC just connect the DATA pin of TX module to TX pin of PIC and RX pin in the case of RX mudule. And use the same UART program.
You can simplify the program or directly control devices by using decoder/encoder ICs linke HT2D/12E. Any doubts post it........
You can simplify the program or directly control devices by using decoder/encoder ICs linke HT2D/12E. Any doubts post it........[/quote]
UART program meaning ?
actually i did try to find from web trying to find some asm source code regarding rf transmitting
do you have any source code or wedsite that teaches the funadamental of using asm code to do tansmitting of data from master pic to slave , an example i mean
thansk for your glad help
hi sorry guys,
is there any good and cheap rf module like tws-434 and rws-434 in singapore?
cos i can't get any in here, can recommend me>?
thanks in advance
