jewung
I have two identical toroid coils taken out of an EDM machine circuit board with the following observations :
1. Dimension ~ 0.37"(OD) x 0.13"(ID) x 0.13"(Height).
2. Core : Toroid with squarish cross section. Painted in smooth green color. Core material unknown.
3. Wire diameter : 0.4mm
4. Windings : Single wire winding, 26 turns.
5. Each coil is connected to the AC input line, 250V 3A glass fuse and then to the input of a bridge rectifier rated 600V 4A.
Would anyone be able to help in identifying the inductance of the coil based on the information above ?
Thanks !
Thanks !
