2bengg
Junior Member level 3
For my final year project i wish to design something that incorporates the following things.
1. 5 devices can be turned ON/OFF using the wall switch (230v AC input).
2. the same 5 devices can also be turned ON/OFF using relays interfaced to a micro controller.
The same micro controller should also be able to detect if a device has been turned ON/OFF using the wall switch. - i need help with this.
So, basically the micro controller should somehow monitor all the 5 wall switches and be able to detect the status of each of the device ie if the switch is ON or OFF.
this needs to be a continuous process.
I am pretty confident about the software part, i need help with the hardware interfacing part.
Problems,
5 switches have to be monitored at the same time.
I wish to have the status of each of the device as a signal (high or low for ON or OFF respectively) on 5 different pins of the micro controller. so that it can be fed to any of the I/O ports of the micro controller.
is this possible ?
i hope that i have been able to explain what i need to do clearly :-?
thanks in advance
Problems,
is this possible ?
thanks in advance
