Help! SPI microcontroller interfacing (TWO 16f877a)
RuH_iranga
Junior Member level 3
sri lanka
Hi all
I am trying to communicate two 16f877a PICs via SPI. But there is a problem. Simply the master write integer 3 into Slave, slave read it and check that value is greater than int 7. If Yes it blink 2 LEDs on RB6 and RB7, else RB6 LED is on.
two codes work correctly on PROTEUS simulator. But in real arrangement, If I send value larger than 7 it blink correctly and some times when I powered two microcontrollers it flash only RB6 as well. Please help me to find where the mistake.
my code
MASTER
// code for spi master
int i;
void main()
trisc.f3=0;
trisc.f4=1;
trisc.f5=0;
trisa.f2=0;
porta.f2=1;
delay_ms(10);
porta.f2=0;
     Spi_Init();
     while(1)
            //int y=7;
            Spi_Write(3);
           portc.f3=0;
SLAVE
    // code for spi slave
void main()
unsigned int buffer, gdata =0;
int c=7;
trisb.f7=0;
trisb.f6=0;
trisa.f5=1;
trisc.f4=1;
trisc.f5=0;
trisc.f3=1;
Spi_Init();
while(1)
         if(Spi_Read(buffer)>=7)
                 portb.f7=1;
                 portb.f6=0;
                 Delay_ms(70);
                 portb.f7=0;
                 portb.f6=1;
                 delay_ms(70);
         else portb.f7=0;
         portc.f3=0;
Please help me to operate this correctly.
Thank you!
I don't know what compiler you are using, I assume the 'Spi_Init()' function call is a built in library function.
Shouldn't you initialize one as a master and the other as a slave?
Both are initialized with the same function call?
I used MikroC compiler. Default Spi_init() initiate followings.
Default settings are: Master mode, clock Fosc/4, clock idle state low, data transmitted on low to high edge, and input data sampled at the middle of interval.
Advanced settings allows below types only
MASTER_OSC_DIV4 // Master clock=Fosc/4
MASTER_OSC_DIV16 // Master clock=Fosc/16
MASTER_OSC_DIV64 // Master clock=Fosc/64
MASTER_TMR2 // Master clock source TMR2
SLAVE_SS_ENABLE // Master Slave select enabled
SLAVE_SS_DIS // Master Slave select disabled
thank you
Try changing one to a slave.
Call Spi_Init(),
and then set the SSPM bits in the SSPCON reg to
0101 = SPI Slave mode, clock = SCK pin. SS pin control disabled. SS can be used as I/O pin.
SSPCON &= 0xf0;
SSPCON |= 0x05;
Thank you btbass!
But still problem remains. Now I'm going to do this without inbuilt functions. and try to do this manually. I'll come with my results soon. And I want to know how can I add Helpful icon.
Thank you again.
---------- Post added at 20:38 ---------- Previous post was at 18:41 ----------
Still no results, please someone help me.
Post your code so we can take a look.
Try using Fosc/16 0r Fosc/64 in master.... send your sspstat and sspcon configiration.
latest code, but still problem remains, do you have any working example code or link.
void main()
int c=7;
trisb.f7=0;
trisb.f6=0;
trisa.f5=1;
trisc.f4=1;
trisc.f5=0;
trisc.f3=1;
Spi_Init_Advanced(SLAVE_SS_DIS, DATA_SAMPLE_MIDDLE, CLK_IDLE_LOW, LOW_2_HIGH);
while(1)
                 portb.f7=1;
                 portb.f6=0;
                 Delay_ms(10);
                 portb.f7=0;
                 portb.f6=0;
                 delay_ms(10);
         else {portb.f7=0;
         portb.f6=1;
         delay_ms(10);}
void main()
trisc.f3=0;            // Clock out from master
trisc.f4=1;            // Data in From slave
trisc.f5=0;            // Data out To slave
//trisa.f2=0;
//porta.f2=1;
//delay_ms(10);
//porta.f2=0;
     Spi_Init();
     while(1)
            Spi_Write(2);
thanks
Hi friends!
I found a problem in one of my 20Mhz crystal oscillator, I think fixing that will be fixed my problem.
thanks.
change your oscillator configuration in your ide to HS oscillator. If you are burning your code in a universal programmer like topwin,select HS oscillator in the configuration bits there also.since you are using a 20Mhz oscillator,set your sspcon register in Fosc/16. It will work
Hi Ram Prasadh
thank you, I' ll try and post my results, but I have exams in these two weeks. As soon as possible I will change my configuration, my burner software is picpgm.
thank you
