Hei
I´m struggling with a new circuit analyze. The question is to determine the equations using KCL and KVL.
And then use superposition to solve current over R7 using :
I=1A, R1=1ohm r4= 1 ohm R5=R6=5 ohm R7=10 ohm V=10V
I would be so happy if someone could help, or maybe recommend som good books or web sites to use.
Why do you call the pile of resistors a circuit? A circuit has a function. What is the function of your pile of resistors? School work? I have worked in electronics for many years and I have never seen a "circuit" like that.
I tried mesh but I got 4 equations using it, i sat up one for the loop with voltage source , 2 loops for the current, and one for the loop with R7. Where do you have your last loop?
Hei
**broken link removed**Hei
c_mitra
What do the impedances of the voltage and current sources have to do with solving the problem?
Ratch
The expressions would simplify if the values of R2 and R3 were known.
Ratch
R4= 1 and R3 = 5
