bubble_d
Junior Member level 3
Hi Edaboard,
I am building 4 single source differential amplifiers which read 4 separate lithium Ion batteries which can be adjusted via a 100k potentiometer. I am having a lot of issues with the single source so far.
Here is my Multisim Schematic.
At first I attached it exactly as the schematic, but I remembered that I need to create virtual ground by dividing the 9 volt supply and using that as my virtual ground. At this point I am working only with the bottom op-amp which is connected to ground..
When I connect all my ground to virtual ground (Except pin 4 of the op-amp which goes to ground) and I from pin 6 to virtual ground I get 4.11V which is unaffected by battery alone, I.E if I pull the battery it it gives me the same value!
Gah this is getting frustrating! Can anyone help me?
