microT
Newbie level 6
Hi ....
I am in the process to develop a wireless system and an using the following components, the details of which are as follows :
Transmitter side :
P89LV51RD2 controller - programmed to send bytes of data serially
Receiver side (using 2 controllers):
Controller 1 - P89LV51RD2 controller - programmed to receive bytes of data serially
Controller 2 - P89LV51RD2 controller - have used this second controller to work as an application controller. Data is send from the Controller 1 to this controller using parallel communication
Further, please note that I am using the following RF devices -
Transmitter - FSK TXB1
Receiver - FSK RXC1
After writing programs for all 3 controllers ... the wired communication works absolutely fine. But when i tried working the same with RF, it does not work. Also note that i have taken care of thebaud rate (2.4K) which is in the range of the used RF devices.
Please ...if anyone could help....
Thanx in advance.
Regards,
MicroT
Transmitter side :
Receiver - FSK RXC1
Thanx in advance.
Regards,
MicroT
