Help required with protel
raghav
Junior Member level 3
I need to use some digital Ics like 4001, 4081, 4017 in my schematic. I can not find a library that gives 40xx series of Ics. Can anybody tell me which libraries to use?Please help.[/b]
centiago
Full Member level 3
Lions Den
You may have to create if you don't have library parts. Else you eqv TTL parts 74xx series.
mobh
Newbie level 1
hello
if you want to find an component in sch of protel99se or dxp ,you can use from find in the bottom of the menu that add anew library and use * before or the end
or middle of component because of the letter that is wiht some component.it's
a easy search to find component but using the letter and * symble in important in
search.i can help you in problem in protel
bye:D
House_Cat
USA
The library components you are looking for are in the Fairchild Semiconductor libraries. They are CD40xxyyy, where the xx is the specific chip and the yyy is the package description.
They should be in your installed libraries, but you can find them on the Altium site by doing a search with just 4001, 4017, etc. listed in the search box at URL:https://www.altium.com/forms/libraries/designer/IntLib_search.asp#results
