guys i have developed a code in assembly for decoding Rc-5 protocol but it seems that there is some problem....
what i am doing is im giving a delay of 8x1.778ms as soon as my start bit puts a zero on 8051 pin(demodulator gives inverted output to 8051) because i am ignoring first 8 bits...
then i am just saving remaining 6 command bits into A register.....
i am using buttons 1-6 of remote which have values 1,2,3......6 respectively..
but as i press buttons on remote nothing happens...i wonder whats the problem
here is my code
ORG 00H
IPIN EQU P1.0
COUNT EQU R0
PIN0 EQU P2.0
PIN1 EQU P2.1
PIN2 EQU P2.2
PIN3 EQU P2.3
PIN4 EQU P2.4
PIN5 EQU P2.5
MOV A,0H
CLR C
MOV COUNT,8
MOV TMOD,01H
MAIN:
JB IPIN,$
DO:
LCALL DELAY
DJNZ COUNT,DO
MOV COUNT,6
CLR C
AGAIN:
MOV C,IPIN
RLC A
LCALL DELAY
DJNZ COUNT,AGAIN
DEV1:
CJNE A,1H,DEV2
CPL PIN0
LJMP MAIN
DEV2:
CJNE A,2H,DEV3
CPL PIN1
LJMP MAIN
DEV3:
CJNE A,3H,DEV4
CPL PIN2
LJMP MAIN
DEV4:
CJNE A,4H,DEV5
CPL PIN3
LJMP MAIN
DEV5:
CJNE A,5H,DEV6
CPL PIN4
LJMP MAIN
DEV6:
CJNE A,6H,MAIN
CPL PIN5
LJMP MAIN
LJMP LAST
;------1.778ms DELAY----------;
DELAY:
MOV TH0,0F9H
MOV TL0,99H
SETB TR0
HERE: JNB TF0,HERE
CLR TF0
CLR TR0
RET
LAST:
END
