Err404
Junior Member level 1
Here's the circuit:
http://www.cs.berkeley.edu/~wkahan/TransIgn.pdf
It's simply designed to ensure that on an old engine with the spark controlled by points the points will not have to carry the current for the coil.
I have access to some BUV46 NPNs
http://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXyzqqvu.pdf
Vce = 400V, Ic = 5A
So I think I can use two in parallel to allow the Vce = 320V, Ic = 10A needed for the original design.
I'm confused as to how to drive the NPN bases in this alternative circuit.
Any help much appreciated!
Vce = 400V, Ic = 5A
