simulation errors in proteus
Cluricaun said:
Hi
Right click then left click U1 and verify you have the correct path to the file (HEX).
Cl
yes i have the correct path to the HEX file.
Cluricaun said:
Hi
You can run ver 2 but not 1??
Cl
yes i can, when i give the HEX file path to "C:/HEW.hex", it is running, but when i put the same HEX file in " .. ver 2/HEW.hex"(as of attached files), the file is not running. also "Hello Embedded World.hex" is not running whether in C:/ directory or in ver 1 directory. both files have the same source code
Cluricaun said:
Hi
You must have the path correctly set to the compilers too, Source DEfine...
Cl
i go to source define.. and checked that my code generation tool is set to ASEM51. is it correct?? i dont know much abt it. but it seems it is correct too else i willnot be able to simulate the file at least once.
thanks
sawaak
Added after 8 minutes:
svicent said:
Copy file HEW.HEX to same folder than file "Hello Embedded Word.DSN". Then right click and then left click U1 and verify you have the new correct path to the file (HEX).
Regards
i done this and the simulation runs, but when i put the file Hello Embedded World.hex in the same folder, this gives error
why?? both hex files have the SAME source code.
thanks
sawaak
Added after 44 minutes:
thanks for helping me guys, at last the problem solves
there is nothing wrong with long paths, it is the SPACE that causes problems.
when simulating in proteus, beware"
There should be NO space in the path to .hex file, including the file name " else u will enjoy some mysterious problems
thanks
sawaak
