I don't think there is a resistance in the problem. Once you are given the voltage across the inductance and the inductance value, you can figure out the inductor current slope. Since vL= L diL/dt, this implies that diL/dt = vL/L. So if you take the given plot and divide it by the inductance you have the slope of the current at any time. You have to begin with the given 0.5A at t=0 and draw the slopes to get the shape of the inductor current. Higher diL/dt value means higher slope. Positive diL/dt gives positive slope and negative diL/dt gives negative slope. There is no resistance or time constant involved in this problem at all. Also the energy is not given in Webers. Webers is the unit of flux linkage and not energy which must be in Joules. The energy in the inductor at 20us is 0.5*L*(iL(20us))^2. So if you know the inductor current at 20us, you will be able to figure out the energy at that time.
Best regards,
v_c
