Haven't seen any automated software to convert .net to 6 version,you got to do it manually, even if it was(which I don't think it can handle all components!), I guess rewriting it will be much more easier than debugging it!!!
Yes you are right but as I do not have any Idea of VB Dot Net I need someone to translate or put some quick comments on the codes.....also do not have VB Dot Net installed and no idea of the files extensions....
I can not write the code my self because the interface information is inside the codes which I could not understand.
The codes are from WIZnet http://www.wiznet.co.kr/en/ product WIZ107SR
Serial to Ethernet converter.
Thanks
Sadat007
