[HELP] PIC18F4550 -- C Programming Problems
scdvom
Member level 1
Hi, I got a problems here. Here is my code
#include <P18F4550.h>
void main (void)
TRISB = 0;	//Make port B as output
PORTB = 0xFF;
when I check d Logic Analyzer (waveform), how come it just trigered wif pin 5,6, and 7 only. then hw pin 1,2,3,4?? i tot 0xFF is all turning on??
can any help me to solve tis problem. thx
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
Are all the pins configured to be digital outputs? Most have more than one use and you may for example, have them configured as analog inputs.
Brian.
scdvom
Member level 1
erm..no...hw can I configure all to be digital outputs??
thx 4 helping
scdvom
Member level 1
hi, Tahmid. thx 4 ur helping again.its work.thx..^^
erm..I got another question here..like I wan to convert decimal form to hex form.can do I make it?
int x
x=3 //actually = 11
y=x //bt y i wish to show "11"...so wat should declare on y??
char y ???
Added after 9 minutes:
sorry..is decimal to binary..
scdvom
Member level 1
here is my code...
void masterStateMachine(void)
	unsigned char fbBits, lrBits, masterBits;
	fbBits = fb.controlBits;				//(fb fb)
	lrBits = lr.controlBits;					//(lr lr)
	masterBits = (fbBits<<2)+(lrBits);		//(fb fb)(lr lr)
	00:Rest
	01:Forward/Left
	10:Reverse/Right
	switch(masterBits)
		case 0: stop(); break;
		case 1: turnLeft(); break;
fb.controlBits and lr.controlBits both are either 0,1, or 3..bt when I wanna store inside fbBits nad lrBits...i need to be binary form.
thx 4 helping
btbass
Advanced Member level 5
Oberon
As far as an unsigned char is concerned, it can only store a binary number????
decimal 3 is stored as 00000011
hex 0x03 is stored as 00000011
It's a matter of interpretation.
PS
Your code doesn't look like a State machine implementation. Looks more like a loop?
