[HELP] PIC18F4550 -- C Programming Problems
scdvom
Member level 1
Hi everyone, I got a question here.
void fbStateMachine()
switch(fb.state)
case 0: if(isForward)
fb.nextState = 1;
case 1: .....
fb.state = fb.nextState;
how do I defined fb.state and fb.nextState in my C code????
thx 4 helping.
btbass
Advanced Member level 5
Oberon
fb.state and fb.nextstate must be part of a structure.
typedef struct
int state;
int nextstate;
int someotherstuff;
}FB;
volatile FB fb;
One approach to a state machine is that each state is atomic, ie: changing the code in the state has no side effects on any other part of the program. You can have a seperate file for each state.
The state can also only switch to another state when something happens that needs a state change.
An elegant way to implement this is to have a constant array of function pointers. The state functions return the next state to switch to as the index in the array.
Here is a trivial example of the stratagy.
/*--- State Machine ---*/
enum STATE{STATE_1, STATE_2, STATE_3, STATE_4}; /* State enumeration */
/*--- State machine function prototypes. ---*/
enum STATE state_1(void);  /* Functions return next state */
enum STATE state_2(void);
enum STATE state_3(void);
enum STATE state_4(void);
/*--- Program entry ---*/
int main(void)
  enum STATE State;
  enum STATE(*const Active_State[])(void) =   /* Constant array of function pointers */
  {state_1, state_2, state_3, state_4};
  State = STATE_1;
  for(;;){
    State = Active_State[State]();  /* execute state machine */
  return 0;
/*--- State 1 ---*/
   enum STATE State = STATE_1;
  while(State == STATE_1)
    /* Code for state 1
    if(Somethings happened){
        State = STATE_2;
  return STATE_2; /* Return next state */
/*--- State 2 ---*/
  return STATE_3;
/*--- State 3 ---*/
  return STATE_4;
/*--- State 4 ---*/
  return STATE_1;
/*--- End of File ---*/
scdvom
Member level 1
Hi, i'm still facing problem, "syntax error". wats going wrong on my code. thx for helping.
volatile fb, lr;
typedef struct
int state;
int nextState;
int controlBits;
}fb;
typedef struct
int state;
int nextState;
int controlBits;
}lr;
void masterStateMachine()
int fbBits, lrBits, masterBits;
fbBits = fb.controlBits; ***** syntax error
lrBits = lr.controlBits; ***** syntax error
masterBits = (fbBits<<2)+(lrBits);
btbass
Oberon
volatile fb, lr; ????
You cant declare these before defining the types! The compiler doesn't know what you are talking about.
You need to study structures a bit more. There is a difference in just defining a structure and defining a type that is a structure.
Also, if you are shifting bits, you should be using 'unsigned int' or 'unsigned char' if it's 8-bits.
/*--- Normal structure ---*/
struct example    /* Structure tag */
  unsigned int variable_1;
  unsigned int variable_2;
/*--- A structure that is a type ---*/
typedef struct
  int state;
  int nextState;
  int controlBits;
  }FB;
volatile FB fb; /* Global instance of type FB */
typedef struct
  int state;
  int nextState;
  int controlBits;
  }LR;
volatile LR lr; /* Global instance of type LR */
void main(void)
  struct example ex; /* Instance of structure 'example' */
  unsigned int test;
  ex.variable_1 = 10;
  ex.variable_2 = 20;
  test = ex.variable_1 + ex.variable_2;
  fbBits = fb.controlBits;   /* Using global fb type */
  lrBits = lr.controlBits;   /* Using global lr type */
  masterBits = (fbBits<<2)+(lrBits);  /* Sign is lost? */
scdvom
Member level 1
Hi Btbass, thx 4 ur guide. jz solve it. ^^ thx.
erm..i got 1 more problem here..once i compile my code. it declare that "old style function declarations not supported". wat d probems on my code here actually. thx 4 helping.
void setMovement(a, b, c, d)
	int a, b, c, d;
	isForward = a;
	isReverse = b;
	isLeft =c;
	isRight =d;
}        ****old style function declarations not supported
