When you code, you usually have <include p18Fxxxx .h >
If you open that file you will see towards the end all the config options.
It is this that sets the defaults - you then change any of them in your code to suit your needs.
Many folk put all the parameters into the code as an extra check that they are set as they want.
Another way to see what you configure options are is in MPlab, Configure, Config Bits.
Notice there is a check box for telling it you are using the config paramenters in your code.
In those two examples your do not want low voltage programming and you do not want the watchdog timer in use.
The one you should be using is the Oscillator selection config bit, unless its the default value you need.
