Help , pic16f877a mcu
yyyyaser
Newbie level 5
Help , pic16f877a , pwm for a motor
why is this code not working?
when set_point < feed_back , the if statement is executed.
but when set_point > feed_back , the it doesn't.
and it is working on the sw debugger but not on the breadboard.
unsigned int set_point , feed_back;
signed int current_duty;
void InitMain() {
PORTA = 0;
TRISA = 0xff; //PORT A FOR A/D CONVERSION
/*ADCON0 = 0x00000001; //PORT A WORKS AS AN ANALOG INPUT NOT DIGITAL */
PORTE = 0; // set PORTE to 0
TRISE = 0; // designate PORTE pins as output
PWM1_Init(20000); // Initialize PWM1 module at 20KHz
void main() {
InitMain();
ADC_Init();
PWM1_Start(); // start PWM1
while (1) {
set_point = ADC_Read(0);
feed_back = ADC_Read(1);
if(set_point<feed_back)
PORTE.B1=0;
PORTE.B2=1;
else if(set_point>=feed_back)
PORTE.B1=1;
PORTE.B2=0;
current_duty = set_point - feed_back;
current_duty = current_duty * (255.0/1023.0) ;
current_duty = abs( current_duty );
PWM1_Set_Duty(current_duty); // Set current duty for PWM1
try to change from "else if" to just "if" ---- at least i don´t ever use the "else if" option because of that weird errors all over...
where do you have this routine working? it can come handy for me ^^
well , I tried both if , else if , neither of them worked.
abs is is a standard library fn available in microC :] , returns the absolute value
void InitMain() {
ADCON1=0x00;
I think you need to config the ADCON1 aswell :S
what a pitty that is on MikroC (abs fn) i use hi-tech C i have to search to see if i have any of those already built in the compiler ^^
It finally worked ,I moved one output to a different port and it worked , but I don't understand why I can't use both pins on the same port .
