cuber18
can you help what transistor should i connect to a cathode row? and what resistors should i use? my led matrix row is connected with a 74ls154 IC w/c output is active low..
you can use sk100 pnp transistor
---------- Post added at 16:59 ---------- Previous post was at 16:58 ----------
can you post circuit diagram
---------- Post added at 17:00 ---------- Previous post was at 16:59 ----------
row scanning or column scanning method ?
---------- Post added at 17:12 ---------- Previous post was at 17:00 ----------
wait a minute since you are using cathode row you should use 40 npn transistors for column
