I need help in devloping vhdl code for a up/down counter using LUT in virtex fpga..Using the Luts avaialble in a CLB i need to develop structural code such that it acts like a up/down counter...i have been able to construct an up counter but am unable to find a solution to include both of them! Please help me out i really am very much stuck
Thanks for the reply vipin. But I need to use components in virtex4 fpga and build a up down counter. so I need to use a 16:1 mux and a D FF (D FF if needed). But in the link there are gates I need it with a 16:1 mux. So any help in this direction is really helpful.
Thanks for the replies. I had to build a pattern generator/updown counter using LUTs. I dont know how to do this because it has 4 inputs and one output and I need a 4 bit up down binary counter .so thats why am using LUT's 16:1 mux . Could you please let me know how to achieve it using constant inputs , or any other efficeint way to achieve this using LUTs.
Is there a specific reason why you're using LUTs instead of a carry chain? Now I'll admit that for a 4 bit counter it doesn't matter so much, but for say a 16-bit counter it might make the difference between failure and success on meeting timing constraints.
I'd think that if you entered behavioral code for an up/down counter the tools would come up with a carry chain.
I need to build a updown counter using a CLB in virtex -4 FPGA. I can only use components inside it
i.e. LUT. So I need to bulid a 4bit binary up down counter using LUTs
The exact problem specification still isn't clear. As already mentioned, the normal way is to define the counter operation in a hardware description language of your choice and let the synthesis tool implement it. You can inspect the gate level netlist to check how it fit's into LUTs and registers.
I assume, that you have been given a homework problem that prescribes a specific way how to implement the design. But seriously speaking, you can't expect that all FPGA practioneers at edaboard will forget their proven methods to implement a design for to follow an arbitrary and badly explained design idea.
That being "As already mentioned, the normal way is to define the counter operation in a hardware description language of your choice and let the synthesis tool implement it. You can inspect the gate level netlist to check how it fit's into LUTs and registers."
Make a boring bit of verilog/vhdl "the usual way" and synthesize it. Then in the technology view you'll see that it uses LUTs (yay! conform homework spec!) and XORCY carry stuff. All happily in a virtex-4 CLB.
That should give you some inspiration. If you then decide that you STILL want LUTs more LUTs and only LUTs, you can implement the logic of the XORCYs etc in more LUTs. Either that or engage brain and think of something clever.
I am not aware of this concept of using carry chains in a CLB and programming in vhdl. I 'll start looking in that direction. Thanks
Yeah I was given a project, asked me to develop a Test pattern gernerator(up down binarycounter ) which uses a CLB in FPGA in VHDL . So I tht I can use LUTs Because it has muxes so its easy to write the code using case statements. But after reading all this am thinking my design can be implemented in a btr way. Sp pls share with me any proven methods for this.
That'll incorporate the concept of carry chains for you, without having to think too hard about it. XST will do al that for you. It doesn't have to be any harder than the above.
