help on pspice student version
silvermirror
Newbie level 6
evaluation version limit exceeded for q devices!
I downloaded a mod LM6172 and added to library
Then, I built a small circuilt which is a voltage follower.
After I clicked simulation button, the error came out.
ERROR -- Circuit Too Large!
EVALUATION VERSION Limit Exceeded for "Q" Devices!
I remembered two years ago, I used student version to simulate a omp, it worked. Why I got the error message this time.
anujgupta.gcet
Junior Member level 1
Greater Noida
do u notice the same error while implementing any other circuit or is it only with voltage follower???
tapa
Super Member
spain
It is possible that the model of the OP you are using has a discrete implementation (a lot of transistors inside the model). Try with an other OP, a simpler model will work.
TaPa
silvermirror
Newbie level 6
pspice student modeling problem
Thank you
I found the problem finally, it is the same as tapa said.
I used some other omp LM324
