help on op amps 741 and 301
mahaju
Full Member level 2
external compensation lm301
Hi
Could anyone please tell me what are the dir\fferences between op Amps lm301 and lm741, and whether they are interchangable in a circuit.
Also, what would happen if the pin 1 of these op amps (offset), were grounded?
Please help.
Thank you.
741 battery charger circuit
LM301 needs external frequency compensation in most applications. It can provide higher bandwidth than LM741 at higher gains and also higher slew rates. I don't think, that any of the said amplifiers will be used for new designs since decades.
Grounding pin 1 prevents operation of both amplifiers, I think.
    mahaju
301 op amp
The LM301 is used in a battery charger circuit where grounding pin 1 turns it on.
Grounding pin 1 of a lousy old 741 opamp stops it from working.
