hoonsk
Member level 2
I have a bandgap reference system that need to measure its noise output in uVrms using spectre. When I open the choosing Analyses option, what should I fill up the Output Noise & Input Noise portion ? For output noise, there is probe/voltage option and we need to select Output probe instance .... is it just selecting the output cap ?
For input noise, there is port/voltage/current and we need to select the corresponding input port, voltage source .... what should I select ?
Thanks !
Richard
Thanks !
Richard
