help on msp430 interrupt
btminzon
Full Member level 2
Brazil
msp430 interrupts
Hi, i´m having some troubles with interrupt handling in C (IAR) with a MSP4302011. My code it seens like this:
#pragma vector=PORT2_VECTOR
__interrupt void p2_isr(void)
if ( (P2IN & 0xC0) == 0xC0)
counter++;
else if ( (P2IN & 0xC0) == 0x80)
counter--;
P2IFG = 0;
return;
in main func:
void main(void)
_EINT();
// Digitally-Controlled Oscillator (DCO) 16Mhz
BCSCTL1 = (unsigned char)CALBC1_16MHZ_;
DCOCTL = (unsigned char)CALDCO_16MHZ_;
// Stop watchdog timer
WDTCTL = WDTPW + WDTHOLD;
// Set P1.0 a P1.6 = OUT(LCD)
//P1.7 = IN(reset)
//P2 = OUT(encoder)
P1OUT = 0x00;
P1DIR = 0xfe;
P2DIR = 0x30;
// interrupt port 2
P2IE |= 0x01;
// Port 2: 0 to 1 edge
P2IES |= 0;
//enable interrupt on port 2
P2IFG = 0x00;
while(1)
some code here...
whats wrong in my interrupt routine? thanks
vhn
Member level 4
msp430 interrupt
Hi btminzon,
It is not advisable to put "return" statement at the end of ISR. Generally the compiler generates a "Return from Inerrupt" assembly instruction at the closing brace of the interrupt routine. But if you forcibly put "return", it may malfunction.
Some intelligent compilers do take care of this, but I'm not sure of IAR.
Just check the disassembly generated by the compiler. If there is not return from interrupt instruction, then that would be the cause of the problem you might be facing.
Regards,
vhn
    btminzon
btminzon
Full Member level 2
Brazil
msp430 interrupt c
Hey Vhn, thanks for the help. In fact, the compiler add automatcaly the "reti" instruction, i didn´t have noticed this before, but the system doesn´t run properly... do you think that the routine to set the clock 16Mhz its ok? i need as fast as possible, with low power, thats why i choose this mc
yager
Member level 5
msp430 interrupt code
The P2 only 2 I/O (P2.6/P2.7) are available for MSP430x20x1.
You have to set correct settings (P2SEL/P2DIR/P2IE/P2IES) for P2 interrupt.
btminzon said:
P2DIR = 0x30;
To affect P2.6/P2.7 only, so why 0x30?
btminzon said:
P2IE |= 0x01;
I doubt whether the P2 interrupt was happened.
(you enable P2.0 interrupt, where is P2.0 in MSP430F2011? BTW, cannot find P2.6/P2.7 interrupt be enable in your code).
FYR
