codemaster11
this is an autocutt off 12v battery circuit based on LM358 ic. set the upper cutoff threshold of the circuit is 13.7vdc
lower turn on threshold is 12.2vdc with bench power supply. output voltage of my smps battery charger circuit is 14vdc.
when i connect the charger, the battery voltage instantly goes to 13.7vdc and relay turn on stop charging process
by removing the charger terminal from battery, the battery terminal voltage shows 12.8vdc on DMM.
why the battery voltage goes to 13.7vdc instantly by connecting the charger? not actually charging the battery to 13.7vdc/13.6vdc.
