ankitmash
Newbie level 1
Hi.
I am using bluegiga wt12 class 2 module. I have just started using it. Is it okay to solder pins using normal iron? Specification sheet says that max temp pin can bear is arond 45 to 70C. So can i work with the module without soldering?
