Help on Allegro (how to assign a net name to a copper area)
bingjiang99
cadence allegro net names
Dear fellows,
I am new to Cadence Allegro (ver. 15.5). I have a headache problem with it. I am designing a two layer board (top and bottom). I am trying to put a piece of metal area on the bottom (ground), and I want to connect it to my input ground. I know I have to assign a net name to it. However, I can't find a way to do it.
Actually, I found a tutorial, which showed that I can do Edit > Change Net. However, I can't find such a menu in my windows.
I also attached my file here. If you have any suggestions, please let me know. I really appreciate your great help.
Thank you,
majnoon
Full Member level 5
allegro assign net
Hi
Select your shape then right click and select Assign net either type your net name or pick a net with cursor.
Regards,
Majnoon
bingjiang99
allegro+change+net+name
Thank you, Magnoo. I figured it out. I have to start with a schematics to have a netlist in the PCB editor. I can't create a net within the PCB editor directly, although the help document shows I should be able to do it. Maybe it can be done with the more advanced version.
majnoon
Full Member level 5
allegronet logic
Hi bingjiang99
Sure you can.
Go to logic<net logic
And follow instructions.
But the best way is to fix it in schematic.
Regards,
Majnoon
