Help needed w.r.t D.A.C and FPGA on Nexsys2 Board!!!
sai1711
Newbie level 5
Hi All,
I got Bazinga'ed by the thing here.
After tinkering around for the past 8 days on my FPGA+ DAC to generate a Sinewave. I am still stuck.
Specs:
128 word deep ROM was used by me on VHDL
Board: Nexsys2
DAC: LTC1668, 16-bit Data In and differential signal IoutA and IoutB
code used:
  ---------------ROM module------------
  library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ROM is
port(	Clock   : in std_logic;
	Reset	: in std_logic;
	Enable	: in std_logic;
	Read	: in std_logic;
	Address	: in std_logic_vector(6 downto 0);
	Data_out: out std_logic_vector(15 downto 0)
end ROM;
architecture Behav of ROM is
    type ROM_Array is array (0 to 127)
	of std_logic_vector(15 downto 0);
    constant Content: ROM_Array := (
0=>"0000000000000000",
1=>"0000001111011101",
2=>"0000011110111000",
3=>"0000101110001110",
4=>"0000111101011100",
5=>"0001001100100001",
6=>"0001011011011010",
7=>"0001101010000101",
8=>"0001111000011111",
9=>"0010000110100110",
10=>"0010010100011000",
11=>"0010100001110011",
12=>"0010101110110100",
13=>"0010111011011011",
14=>"0011000111100011",
15=>"0011010011001101",
16=>"0011011110010101",
17=>"0011101000111011",
18=>"0011110010111100",
19=>"0011111100010111",
20=>"0100000101001011",
21=>"0100001101010101",
22=>"0100010100110110",
23=>"0100011011101011",
24=>"0100100001110100",
25=>"0100100111001111",
26=>"0100101011111100",
27=>"0100101111111010",
28=>"0100110011001001",
29=>"0100110101100111",
30=>"0100110111010101",
31=>"0100111000010010",
32=>"0100111000011110",
34=>"0100110111111010",
35=>"0100110110100100",
36=>"0100110100011110",
37=>"0100110001101000",
38=>"0100101110000001",
39=>"0100101001101011",
40=>"0100100100100111",
41=>"0100011110110101",
42=>"0100011000010110",
43=>"0100010001001011",
44=>"0100001001010101",
45=>"0100000000110110",
46=>"0011110111101111",
47=>"0011101110000000",
48=>"0011100011101101",
49=>"0011011000110101",
50=>"0011001101011100",
51=>"0011000001100011",
52=>"0010110101001011",
53=>"0010101000010111",
54=>"0010011011001001",
55=>"0010001101100010",
56=>"0001111111100101",
57=>"0001110001010100",
58=>"0001100010110001",
59=>"0001010011111111",
60=>"0001000101000000",
61=>"0000110101110110",
62=>"0000100110100011",
63=>"0000010111001011",
64=>"0000000111101111",
65=>"1111111000010001",
66=>"1111101000110101",
67=>"1111011001011101",
68=>"1111001010001010",
69=>"1110111011000000",
70=>"1110101100000001",
71=>"1110011101001111",
72=>"1110001110101100",
73=>"1110000000011011",
74=>"1101110010011110",
75=>"1101100100110111",
76=>"1101010111101001",
77=>"1101001010110101",
78=>"1100111110011101",
79=>"1100110010100100",
80=>"1100100111001011",
81=>"1100011100010011",
82=>"1100010010000000",
83=>"1100001000010001",
84=>"1011111111001010",
85=>"1011110110101011",
86=>"1011101110110101",
87=>"1011100111101010",
88=>"1011100001001011",
89=>"1011011011011001",
90=>"1011010110010101",
91=>"1011010001111111",
92=>"1011001110011000",
93=>"1011001011100010",
94=>"1011001001011100",
95=>"1011001000000110",
96=>"1011000111100010",
97=>"1011000111101110",
98=>"1011001000101011",
99=>"1011001010011001",
100=>"1011001100110111",
101=>"1011010000000110",
102=>"1011010100000100",
103=>"1011011000110001",
104=>"1011011110001100",
105=>"1011100100010101",
106=>"1011101011001010",
107=>"1011110010101011",
108=>"1011111010110101",
109=>"1100000011101001",
110=>"1100001101000100",
111=>"1100010111000101",
112=>"1100100001101011",
113=>"1100101100110011",
114=>"1100111000011101",
115=>"1101000100100101",
116=>"1101010001001100",
117=>"1101011110001101",
118=>"1101101011101000",
119=>"1101111001011010",
120=>"1110000111100001",
121=>"1110010101111011",
122=>"1110100100100110",
123=>"1110110011011111",
124=>"1111000010100100",
125=>"1111010001110010",
126=>"1111100001001000",
--127=>"1111110000100011",
--128=>"0000000000000000"
--63=>"0000000000000000",
	OTHERS => "1111110000100011"
begin
    process(Clock, Reset, Read, Address)
    begin
        if( Reset = '1' ) then
	    Data_out <= "ZZZZZZZZZZZZZZZZ";
        elsif( Clock'event and Clock = '1' ) then
	    if Enable = '1' then
		if( Read = '1' ) then
		    Data_out <= Content(conv_integer(Address));
            	else
            	end if;
	    end if;
        end if;
    end process;
end Behav;
--------------------------------------------------counter module to count 4-bit address------
 library ieee ;
entity counter is
 port(	clock:	in std_logic;
	rst:	in std_logic;
	count:	in std_logic;
	Q:	out std_logic_vector(6 downto 0)
end counter;
architecture behv of counter is
    signal Pre_Q: std_logic_vector(6 downto 0);
begin
    -- behavior describe the counter
    process(clock, count, rst)
    begin
	if rst = '1' then
 	    Pre_Q <= "0000000";
	elsif (rising_edge(clock) and rst='0') then
	    if count = '1' then
		Pre_Q <= Pre_Q + '1';
	    end if;
	end if;
    end process;
    -- concurrent assignment statement
    Q <= Pre_Q;
end behv;
-------------------------------------------- clock---------------------------
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clk1mHz is
    Port (
        clk : in  STD_LOGIC;
        reset  : in  STD_LOGIC;
        clk_out: out STD_LOGIC
end clk1mHz;
architecture Behavioral of clk1mHz is
    signal temporal: STD_LOGIC;
    signal counter : integer range 0 to 26 := 0;
begin
    frequency_divider: process (reset, clk) begin
        if (reset = '1') then
            temporal <= '0';
            counter <= 0;
        elsif rising_edge(clk) then
            if (counter = 26) then
                temporal <= NOT(temporal);
                counter <= 0;
            else
                counter <= counter + 1;
            end if;
        end if;
    end process;
    clk_out <= temporal;
end Behavioral;
--------------------------------------------------------------------MAIN MODULE-------------------------------------------------------
library IEEE;
use IEEE.NUMERIC_STD.ALL;
entity sinecounter is
port (clk,reset,resetclk,rst,En,read,count: in std_logic;
clk_out: out std_logic;
sine: out std_logic_vector(15 downto 0));
end sinecounter;
architecture Behavioral of sinecounter is
component counter is
	rst:	in std_logic;
end component;
component clk1mHz is
    Port (
        clk : in  STD_LOGIC;
end component;
component ROM is
end component;
signal tempo: std_logic_vector(6 downto 0);
begin
x1: counter port map( clock=>clk, count=>count, rst=>rst,Q=>tempo);
x2: clk1mHz port map ( clk=> clk, reset=>resetclk, clk_out=> clk_out);
x3: ROM port map(Clock=>clk, Reset=> reset, Enable=> En, Read=>read, Address=> tempo, Data_out=> sine);
end Behavioral;
UCF file :
Net "clk" Loc ="B8";
Net "sine(0)" Loc ="J13";
Net "sine(1)" Loc="M18";
Net "sine(2)" Loc="N18";
Net "sine(3)" Loc="P18";
Net "sine(4)" Loc="G15";
Net "sine(5)" Loc="J16";
Net "sine(6)" Loc="G13";
Net "sine(7)" Loc="H16";
Net "sine(8)" Loc="M13";
Net "sine(9)" Loc="R18";
Net "sine(10)" Loc="R15";
Net "sine(11)" Loc="T17";
Net "sine(12)" Loc="L15";
Net "sine(13)" Loc="K12";
Net "sine(14)" Loc="L17";
Net "sine(15)" Loc="M15";
Net "clk_out" Loc="H15";
Net "reset" Loc="G18";
Net "resetclk" Loc="H18";
Net "rst" Loc="K18";
Net "En" Loc="K17";
Net "read" Loc="L14";
Net "count" Loc="L13";
DAC Output
aruipksni
Full Member level 6
Hi All,
Specs:
Board: Nexsys2
code used:
  library ieee;
entity ROM is
end ROM;
begin
    begin
            	else
            	end if;
	    end if;
        end if;
    end process;
end Behav;
 library ieee ;
entity counter is
	rst:	in std_logic;
end counter;
begin
    begin
	if rst = '1' then
 	    Pre_Q <= "0000000";
	    if count = '1' then
	    end if;
	end if;
    end process;
    Q <= Pre_Q;
end behv;
library IEEE;
entity clk1mHz is
    Port (
        clk : in  STD_LOGIC;
end clk1mHz;
begin
            temporal <= '0';
            counter <= 0;
                counter <= 0;
            else
            end if;
        end if;
    end process;
end Behavioral;
library IEEE;
end sinecounter;
	rst:	in std_logic;
end component;
    Port (
        clk : in  STD_LOGIC;
end component;
component ROM is
end component;
begin
end Behavioral;
UCF file :
Net "En" Loc="K17";
DAC Output
3 issues i like to raise :
1. sensitivity list : if you are implementing synchronous process then only clk or (async rst_n if you want)
should be written.
2. asertion to 'Z' : you better use iobuffer primitive, and why you actually do this ? (it's not like you have a bi-di bus to drive)
3. you better use the ROM primitive to be on the safe side.
and ofcouse edit this post to include VHDL syntax.
your plot look like some random noise to me, so check you hardware, and scope.
mrflibble
Advanced Member level 5
Well, it's definitely periodic, but not exactly sine wave. Closer to a triangle wave with superimposed noise...
Anyways, the ever popular question: have you put it through a testbench yet?
sai1711
Newbie level 5
Yes, its a popular question and everytime has its own local problems. :))
I have not taken it through a TB.
Aftre burning my DAC.
As an alternative I tried the LC-Low pass filter trick. With Delta-sigma thing. Didnt work either.
The Delta sigma module individually is working fine.
The ROM module with counter is individually working fine.
But only when the modules come together, they aint working at all. :(
I am almost at the verge of a certain vexation.
FvM
Super Moderator
Staff member
Bochum, Germany
How can we know that the DAC is connected correctly? If you verified the data sent to the DAC, it's obviously a hardware problem.
Giving a binary counter output to the DAC would be a simple way to check for correct data line order and complete connection.
mrflibble
I would check my power supply and grounding. The wiring looks potentially a bit optimistic. What is the frequency of the clock signal you're sending to that LTC1668? Anyways, I'd make the ground connection between board + DAC a bit beefier and maybe add some bypass caps. Then lower the update frequency and see what we can see on the scope.
That, and double checking a couple of data pins on the DAC with the scope is probably a good idea as well. For that you'd want just a regular binary counter as output, just like FvM suggested. That's easier to watch than bit number 3 of a sine wave for example. ;)
sai1711
Newbie level 5
Genau, I shall do that today
The max rated clock frequency of the DAC LTC1668 is 1 MHz. I am feeding in 917 kHz, from the clock divider module. the reason for 128 words deep ROM is the same, i.e. to have a frequency of sampling satisfying nyquist sampling theorem, because with 128 Words and 917 KHz> 2* Freq of the sinewave being generated.
I suspect the wiring to be a culprit too. I shall look to add some caps and see. And I will get back with the outcome.
BTW the Sigma-Delta method posted here: http://designingwithfpgas.blogspot.kr/2011/10/one-of-downfalls-of-fpgas-are-digital.html
http://designingwithfpgas.blogspot.kr/2011_11_01_archive.html
didnt work either.
mrflibble
In that case feeding it a 1 kHz clock signal with a simple binary counter would be a nice test. That should then give you a nice slow sawtooth on the scope.
Not sure what the delta-sigma thing has to do with this? That sounds like it's a totally seperated issue from the LTC1668. LTC1668 ==> most likely crap wiring. delta-sigma not working ==> most likely crap coding. ;)
Delta sigma is easy enough to debug though. Just run through a testbench, spit out the 1-bit data stream to text file. Then do some low-pass filtering in your favorite math tool. Matlab, octave, whatever.
