[SOLVED] help needed to measure amps in a battery charge circuit
speedEC
Full Member level 6
help needed to measure amps supplying into battery from battery charge cicuit
Dear all,
I have made Battery charge circuit for my 6v, 4.2 mAh lead acid battery. Battery is charging fine. But, I don't know how to measure the amps that is going into Battery from charger circuit. Pl help me.
Thanks
pmk
Just connect the ameter serially to any lead of the battery ..
i can calculate volts easily. but, i cannot able to calculate amps going into battery.
thanks
Finally I can able to read amps. I forgot to select the 10A on multimeter. Now it is OK. Thanks Thanara.
