help needed to implementinh some formula on xilinx FPGA
vaf20
Full Member level 3
help needed to . . .
hi all
i would like to implement following formula on xilinx FPGA
A=(Sqrt(x^2+y^2)*Sqrt(z^2+t^2))/(Sqrt(k^2+H^2)*Sqrt(L^2+M^2))
B=[ArcTan(x/y)-ArcTan(z/t)]-[ArcTan(k/h)-ArcTan(l/m)]
i know i can implement Sqrt and Arctan or even sin , ... by implementing cordic block,but i feel there is better way to do it.
how i can implement exactly with better method?
how about xilinx coregenerator - cordic block , anyone try it?
any comment or idea or help is highly appreciated
vaf20
Full Member level 3
Re: help needed to . . .
hi again
i think this message is not off-topic but i can not undrestand why there
is no idea or comment!
is there anyone ot drop message to help me?
thanks
r_e_m_y
Member level 4
may be nobody on this forum has ever tryed to implement an ArcTan function in a FPGA.
If I had time to spend on it, I would help you, but I can't.
ashishjindal76
Member level 4
try for the embeded solution or system on chip solution that would really help u out and impliment it on fpga.
ashish
vaf20
Full Member level 3
tnx really 2 ashish
can u tell more about embeded solution or system on chip solution ?
Big Boy
Full Member level 4
Look at opencores.org, I remember seeing a co-processor core.
From there, implementing roots and trigo are more complicated. You will need to do it over multiple clock cycles. I suggest looking for papers on series expansion (for trigo functions) and on root extractions.
In any case, you can't implement those as a single clock cycle operations.
eltonjohn
To implement that in a core .. You need Matlab .. Then Sysgen .
to generate a core in VHDL with that equation
vaf20
Full Member level 3
tnx 2 eltonjohn
can anyone tell me more about this method ?
any help!
thanks in advance
