Help Needed: P18F452 and Serial Port
medorpg
Newbie level 5
Newbie level 5
I Really need your help in connecting my PIC18F452 to PC
I don't know where to start
if there's any book or a tutorial which is suitable to my PIC it would be great
I have the Max232 chip and the needed hardware
What I mainly need is
sending strings from the PIC to the PC Terminal
and sending chars from PC Terminal to PIC
it's a project in my college PLEASE HELP
vijay s
Full Member level 3
Full Member level 3
Coimbatore, India
oops... you forget to inform what compiler you are using??
Any how i have given the code For Hi-Tech compiler
use below function to send a character from PIC to PC
void putcUART(unsigned char Chr)
	while(!TXSTAbits.TRMT);
	TXREG = Chr;
use below function to send string from PIC to PC
void putrsUART(const unsigned char *str)
	while(*str)
		putchUART(*str++);
Reply what compiler u are using and what exactly u need
__
Click Helped Button if it helps you
    medorpg
medorpg
Newbie level 5
Newbie level 5
Sorry,
I'm using MikroC
and for simulation I use Proteus ISIS
I am using C for programming, What language you used here ?
vijay s
Full Member level 3
Full Member level 3
Coimbatore, India
The program i wrote above is for Hi-Tech Compiler in C Language....
if you are using MikroC, ur work is very simple....
MikroC comes with rich library.. goto Help file and search for UART Functions.. it will show you the library functions to send string from PIC to PC...
and there will be an function to accept character from PC in PIC... use that function in interrupt ISR ,so every time you get a character from PC, u can read that....
use MikroC Help file and Search this Forum for existing discussion
medorpg
Newbie level 5
Newbie level 5
I used the Usart_Init(9600); command
then Usart_Write(CC);
CC is a char variable
but nothing works
please help
vijay s
Full Member level 3
Full Member level 3
Coimbatore, India
I'm not familiar with MikroC library files....
check ur Hardware.... check the voltage level in MAX232 chip as specified in Datasheet....
Config receiver pin of RX as input and TX pin as Output.. read Help file about using UART..
sumiii
Junior Member level 3
I want to convert hex(result generated from A/D) to ASCII in order to transmit serially data.
Plz help me
hussain_kiet
Full Member level 5
Full Member level 5
Karachi, Pakistan
Plz help me
do you want to transmit ascii equivalent of hex value or ascii equivalent of decimal value...
eg ADC read 0xFF which is 255 in decimal now what you want to transmit
"FF" ASCII format
or
"255" ASCII format
sumiii
Many ADC chips provide data in binary (hex). To display the data on an LCD or PC screen we need to convert it to ASCII.
I am using C-language and hi-tech compiler and PIC18FXX series ...
I hope you understand my problem.
