Register Log in
Help needed in using AT89C4051 as an ADC
vinash
Member level 2
I am using AT89C4051 to utilize it as an AD Converter for an application as a two digit Voltmeter. I am following the circuit design given in the following address:
h**p://www.atmel.com/dyn/resources/prod_documents/DOC0524.PDF .
I have written a code in C and it does not work. It would be very helpful if someone were to help me if there are any mistakes in my code. My code is:
#include<AT89x051.h>
#define TON 79;
#define TOFF 79;
unsigned int ta,tb;
char a[10]={0x07,0x17,0x27,0x37,0x47,0x57,0x67,0x77,0x87,0x97};
char b[10]={0x0B,0x1B,0x2B,0x3B,0x4B,0x5B,0x6B,0x7B,0x8B,0x9B};
scanled();
void main(void)
int td,tc,m;
tc=TON;
td=TOFF
while(1){
P3_7=1;
for(m=0;m<tc;m++){
if(P3^6==0)
ta++; }
P3_7=0;
for(m=0;m<tb;m++){
if(P3^6==1)
tb++;
scanled();
scanled(){
unsigned int i,flag,j;
if(tb==0){
for(i=0;i<2;i++){
flag=1-flag;
if(flag==1){
P1=a[(ta)/10];
for(j=0;j<32000;j++);
P1=0xFF;
if(flag==0){
P1=b[(ta)%10];
P1=0xFF;
else if(ta==0){
for(i=0;i<2;i++){
flag=1-flag;
if(flag==1){
P1=a[(tb)/10];
P1=0xFF;
if(flag==0){
P1=b[(tb)%10];
P1=0xFF;
I really hope someone would be able to assist me as i have been desperately doing this for the past weeks without any yield. Thank you so much
Jack// ani
Advanced Member level 3
Which A/D convertor are you using??
vinash
Member level 2
I am not using an external AD converter.I am trying to utilize the analog comparator in AT89C4051
silvio
Romania
You wrote:
P3_7=0;
for(m=0;m<tb;m++){
if(P3^6==1)
tb++;
If it's not a typewriter mistake, the "tb" wrote in red color shouldn't be "td" ?.
Did you read carefully the doc ?
It's clearly stated that before doing any display, the value must be adjusted according to a lookup table.
I don't see this in your code.
It's true that you used two array for either charge or discharge portions of the measurement cycle (ta or tb).
But it's useless as long as the charging and discharging of the capacitor it's not linear.
Are you sure that :
1. when you compile the code, the value of XTAL is 12 Mhz ? Just because all delays are strong related to that assumption.
I mean the value of TON 79 is defined as the minimum number of samples which must be taken to guarantee that the voltage on the capacitor has reached Vcc/2.
More, the maximum conversion time is 7ms (sample interval = 5us) according to the choosen values of resistor = 267 kilohms; capacitor = 2 nanofarads; Vcc = 5.00 Volts.
2. I don't see in your code the additional NOPs mentioned in the original code used to delay the first
sample in the charge and discharge portions of the measurement cycle and as a result an effect on mesurement accuracy (why making worst than it is with this kind of measurement)
3. When you get into scanled() routine, are you sure that the value of "flag" is either 0 or 1 ? What would happen if has a random value when "flag=1-flag;"
    vinash
vinash
Member level 2
Thanks for pointing out the mistake of tb.
As for the lookup table, i am not using the lookup table. I just want to know the number of counts. From the number of counts, i could refer to the lookup table manually and get the voltage output.
Thanks for your suggestion on the 7ms interval, i forgot to include that.
Thank you for your suggestions....
vinash
Member level 2
HI silvio,
I have done the changes as you had stated, but i still am not able to get it working...Pls do help...My corrected code is below for your reference.
#define TON 79;
#define TOFF 79;
unsigned int ta,tb;
void delay(int count);
scanled();
void main(void)
int td,tc,m;
tc=TON;
td=TOFF
while(1){
P3_7=1;
for(m=0;m<tc;m++){
if(P3&0x40==0)
ta++;
delay(3);
P3_7=0;
for(m=0;m<td;m++){
if(P3&0x40==1)
tb++;
tb=tb+td;
delay(3);
scanled();
scanled(){
unsigned int i,flag=0,j;
static unsigned int k,h;
k=ta;
h=tb;
if(tb==0){
for(i=0;i<2;i++){
flag=1-flag;
if(flag==1){
P1=a[(k)/10];
P1=0xFF;
if(flag==0){
P1=b[(k)%10];
P1=0xFF;
else if(ta==0){
for(i=0;i<2;i++){
flag=1-flag;
if(flag==1){
P1=a[(h)/10];
P1=0xFF;
if(flag==0){
P1=b[(h)%10];
P1=0xFF;
int j,l;
for(j=0;j<= count;j++)
for (l=0;l<=120;l++);
Really do appreciate your help. Thank you.
