Donragu
Newbie level 1
Hi Everyone,
I wonder if you can help you me out. I am looking to program at24c64 chips, to replace faulty ones on an automotive system. I currently use Batronix BX40 programmer, but unfortunately they do not have the adapter for the chip size i need. There seems to be different versions of the 24c64, but i'm after the 4.4 x 3 mm version, listed as TSSOP−8 Y SUFFIX CASE 948AL, in the date sheet.
Is there another way of writing to these chips, without using my batronix, or is there an adapter out there, that can be compatible with my batronix programmer?
I will also need to read data from a working chip, so that can be used to write.
Thank you for any information.
