Register Log in
Help needed in driving Bipolar Stepper motor
shohaib1
Junior Member level 1
pakistan
i am trying to drive bipolar stepper motor, i have got no special bipolar stepper motor driver IC, instead i m using a Power supply which can give current upto 1A,
first of all, i found resistances between different terminals,
which found to be...
RED-------9.7 Ohm-----yellow
orange----9.7 Ohm-----blue
Now i connected RED with +5V and yellow to blue to gound,
But i am unable to get rotation, but instead i get jerks only,
and motor produces SOUND like high frequency SssssssEEEEEEEEEEEEEEEEEEEEEE
So please guide, what i am doing wrong,
I have tried much, but in vain...........
2 paint files are available for better description of what i am doing
Note:
motor is from a old floppy drive,
5V, 1.8 degree motor
elrayes
Full Member level 5
Egypt/Canada
I think its better for you to use driver IC's, I recommend for you L297 stepper motor controller with L298 dual h-bridge IC, you will need both of them to control your bipolar stepper motor, beside you will be able to control your motor speed and direction from either a PC port (e.g. parallel port) or from microcontroller.
let me know if you had any problems.
shohaib1
pakistan
what do u mean by Dual H-Bridge??
do u mean that there are 2 poles so we need one H- Bridge for each Pole??
i was started on thinking like this because 4 transistors were required for a single H-Bridge like:
SEE the attached link........
Driving Bipolar Stepper Motors
and if there are 2 poles, then we will require 8 Transistors, means 2 H- Bridges
elrayes
Full Member level 5
Egypt/Canada
Dual H-bridge: 2 H-bridge circuits inside the IC.
driving the bipolar stepper motor coils requires to invert the polarity of the applied voltage on the coils to move the motor, so the H-bridge will give you this.
this IC (L298 ) is capable of handling up to 2A current, so my opinion don't use transistors and use this IC instead.
shohaib1
pakistan
Thanks sir,
i am cleared on the point, I have checked the motor by giving pulses to its coils in specific sequence and it works as desired,
Now i just want to ask,
which switching transistors should i use for switching in motor??
I want to use discrete components, no ICs, So please list me some switching transistors, Which can be get easily......
is 2N2222 will work??
or BC547 will work??
FvM
Super Moderator
Staff member
Bochum, Germany
I think you can answer the question yourself by calculating the currents. It should be capable at least of 0.5 A for your motor, better get some margin, e.g. using 1 A switching transistors. I guess you'll want to have complementary types, and you shouldn't forget the free wheeling diodes. In my opinion, using compementary MOSFET reduces the part count considerably, you can drive them by CMOS logic and don't need separate diodes.
hameeds01
Advanced Member level 2
Islamabad Pakistan
Thanks sir,
y u don't want to use any IC ??
check this out
YouTube - how to control CDROM Bipolar Stepper motor
MOD: I see you ulpoading your video's or suggesting the youtube video of your projects. But just showing video does nothing but advertising yourself and your products. So you may continue that in the advt section meant for.
Toggle Sidebar
